Thermostat
Cocobum
Florida
I have just replaced my thermostat but i was unable to get a 190 degree thermostat which is what my bronco had stock. Instead I had to use a 180 degree thermostat. I'm in South FL so the summers are pretty hot and I tow frequently so I was under the impression that cooler was better but a friend told me I would have dramatically reduced MPG, is this true? Are there any negitive side effects of running a cooler thermostat?
Mike @ Tracy
winnemucca nevada
I live in nevada and I run a cooler thermostat, REAL HOT here in the summer. So far the only draw back that I can name is the longer warm up time on really cold mornings. I have been told that the engine wont run efficiently because its not reaching its correct operating temp. but I havent noticed much change.
big95ford
You should not notice any changes with that termostat. you might notice something with a 160 degree becouse you will not reach operating temp but 180 is pretty close.
C
Cocobum
Florida
Wow I had no idea that a thermostat under 180 could hurt the engine, since I'm right on that temp do you guys think I should step it back up to 190?
shuagriz
Avondale, AZ
I think 180 should be ok for were you are. With the OE spec thermasts you don't have to worry, but its your call. Running an engine to cold will cause rapid wear of engine parts and could cause sludging of the engine oil, but I don't think you will have to worry about that.
One factor is the thermostat, a hotter engine gets better fuel economy while a cooler one can develop more power. However, don't forget we are not talking about the most economical vehicle in the world here. Since you are putting the additional stress on the engine of towing, the important thing is to look at the overall cooling system. I'll bet you even want to run A/C while doing that ;) /emoticons/[email protected] 2x" width="20" height="20" /> . Then more important than your tstat is the radiator size and something like a transmission oil cooler.
As far as running a cooler thermostat for hot weather, if your engine is overheating there is some problem with your cooling system. I run a 195 tstat all year long and never have a problem. Some will argue that it is because it doesn't get that hot on the East coast, BUNK. I run plenty on 4 lane highways that have air and surface temperatures equal to any desert conditions. The key to keeping the engine from overheating, is a cooling system that is efficient and large enough for the environment it is in. My engine runs rock solid at 195 year around no matter what the air temperature is. You might notice from my signature though, that I don't have a stock fan, I also have a transmission cooler and a over sized radiator.
People who run stock cooling systems at low RPM such as off roading in the deasert, for example, have some strikes against them. The main one being that their water pump is running at a very inefficient speed. One of the solutions there is to run an electric pump that keeps a high volume of water moving thru the system. Another solution is to run a larger than stock radiator to increase the cooling capacity plus a high volume electric fan.
Oh well, enough babble.
Coastersfwb
