Finally fixed the bushings on the linkage with my hurst 3 speed and found out previous owner had bent rods also. Drove for about 10 minutes and noticed a lot of coolant (green) fluid pouring out of the radiator hose. I was about to install a reservoir plastic case bought from a local parts store for the overflow, but thought this is not normal. I am sure someone has encountered this problem with the EB's. Do i need a new radiator or do the thermostats need to be changed frequently and could this be the problem instead. Thanks for the help in advance.
Also have a two stage paint i sprayed on myself and some grease seems to be impossible to get off and spots. I tried paint thinner and no luck, any suggestions as well.
