tailgate wiring diagram
93brons
hi i am new to this site i just bought a 93 bronco xlt with 5.8 auto i cant get the tailgate motor to work i am geting power to the switch in the back the red/yellow wire has power wen i turn the switch but the yellow/red wire has no power if aneyone has a diagram of a 93 tailgate i would be thankful thanks sam
The ground side has to go all the way back through the driver switch. Have you tried to jumper it to see if it is the motor or the switch control? When you turn the switch, you should have 12 volts on one side and a ground connection on the other. Turning the switch the other way reverses the connection.
93brons
The ground side has to go all the way back through the driver switch. Have you tried to jumper it to see if it is the motor or the switch control? When you turn the switch, you should have 12 volts on one side ans a ground connection on the other. Turning the switch the other way reverses the connection.
thanks seabronc i got it fixed one wire broke
Staff online
Gryph
