Swapping axles
My Little Mule
MN
Hi Guys!
I has been awhile since I have been here but am ready to dive into my Broncos.
I have a 78 that has full time 4wd with 3.50 gears and a 79 with 4.11 gears and lock out hubs.
Question is....
I want to put the front axle from the 79 into the 78. I use the 78 as a trail rig and want the extra low end power from the 4.11s.
I can see no problems with doing this as aside from the obvious performance changes. I know that transfer cases are different in that the full time case does not have a 2wd option only 4wd hi, 4wd low and neutral. I would just change out the center sections but don't have the skills to set up them and am thinking of just switching the axles. I have already switched the rear axles.
Anyone done this before or see any potential issues?
Thanks for any advice.
I don't see any problems with that at all. Should just be a bolt in swap and I agree it is easier to swap axles then center sections.
Gives you a chance and new caster bushings, radius rod bushings. Nice refresh if needed.
M
My Little Mule
MN
Thanks Tiha!
that is kind of what I was thinking but thought I should ask the experts first.
BigJim4x4
