Ok, before I spend umpteen hundred $$$ on a mechanic, I figured I would check here:
I have started to notice this weird noise comeing from my front left hub area. It sounds both grinding, and a little whining/squeaking...you can also feel it grinding, but not all the time. It is worst when I am accelerating from a stop with the wheels turned to the left. I havent taken the hubs apart yet, but I probably wouldnt be able to tell you whats wrong even if I did. All in all, it hasnt done anything bad, other than the noise kinda scares me, since strange noises are generally bad...but I was wondering if anyone could give me a diagnosis, from what little info I gave you. Oh yeah...I have auto locking hubs right now, but I am about to switch to manual. I did however, put the truck up on jackstands and spun the hub, and I am pretty sure its from the hub somewhere since it was in 2wd, and the axle wasnt spinning, but it was still making the squeaking noise.
Can anyone help me? Anyone had this before? Tell me its just that the auto hubs are ***** since I am going to switch them out next weekend sometime.
Thanks
Oh yeah...someone told me it might be the bearing might be going out, or the snap ring or something. Does the auto-manual conversion kit come with those bearings and all that, or do I have to buy those seperate?
Thanks
