spark plugs
broncodriver33
Palmyra, Pa
Just curious, with all the different types of spark out there. I personally normally just stick with bosch platinums. unless any one can recommend better.
4WHEELIN
New Jersey
i run the accel double platinum plugs and accel 8mm wires and i noticed the difference, my engine runs smoother and quiter
wileec
Erie CO
The stock coppers from Ford or autolite are my choice with good wires and a strong coil.
crazyhorse85
clarksville,tenn
I MYSELF REALLY LIKE CHAMPION TRUCK PLUGS...TO ME THEY WORK GREAT ALONG WITH 8.8 MM WIRES AND ACCEL SUPER COIL...USE TO RUN AUTOLITE THEY WORK FINE FOR STOCK TO VERY MILD BUILD, BUT TO ME SEEM TO FOUL OUT A LITTLE FASTER THAN CHAMPION PLUG, MAY JUST BE MY IMAGINATION...BUT WITH MY 351W .040 OVER AND RV CAM AND HOLLEY 750 DUAL LINE CARB.CHAMPION HAS HELD UP FAIRLY WELL...
bidibronco
Norfolk Va
I run champion in my 94 and I'll be doing a .030 over with a mild cam and an itake and exhuast (just a little different than my current set up) and I'll continue using them. I like them and they're not expensive and they're good!
Val
