sounds angry!
jonn'athen
after a desperate need of a new manifold gaskets on my 2.9L B2 and calibrating my timing she(her name is B.A.B'S= Bad Ass Bronco.S) still won't work properly. i can get her to turn over but she can barely idle for more than ten secs! but when i open the choke she seems to run a little better. when i drove her she had an extremely hard time getting up to speeds, barely into 3rd gear. iIm thinking it is the timing but after that i wouldn't know where to look, any suggestions or help diagnosing this problem would be extremely appreciated :closedeyes: .
hifooy07
monongahela pa
did you check your vacuum lines? did you disconnect the spout connecter when checking or setting the timeing?
kyleh01
