Some Serious Bronkidillo Issues
quiggs00
ok so i got a 93 fullsize bronco with a 5.0 standard tranny. i was cleanin the dash and steering column with some fantastik the other day and i was sprayin it all over. i think some must have dripped down into the column cause when i went to start it up i turned over half a crank and everything went dead dash, lights, radio, rear window and nothing when i turn the key. i have taken out the lock cylander to inspect but i dont know whats going on. one time jiggling the key cylinder while turning it i got the dash lights to come on and it clicked like it wanted to turnover. but i tried many more times and nothing. also the voltmeter jumps like 1/16 of an inch when i turn the key on but thats the only noticeable change at all. what the **** is going on? any insight would be nice thanks in advance!!!
You probaboy blew a fusable link supplying the power from the battery to the rest of the truck. Since you lost everything I would suspect the one connected to the Start Relay. Keep in mind I'm speaking from a 80 - 86 Bronco point of view. I believe 87 - 96 still used fusable links at least the ones in the 80's did. The link should be aattachec directly to the Start Relay at the end of a yellow wire.
OOPS the wire color is black with Orange stripe. you can see a fusable link attached to the end of it in the picture above.
Good Luck,
Also, I have scaned in some picts of the power distribution in the previous post about electrical problems. The diagram won't be 100 percent for your truck but will be close. I worked on a 96 the other day using the info from my 83 EVTM only found minor differences.
Good luck, :)>-
Also, the water probab ly got into the actual start switch not the key switch. The start switch is located on the top of the column about a foot from where it goes thru the firewall. It has a mass of wires plugged into it. Blow it out if you can. A rod connects the key switch to the start switch. If you remove it, make sure you mark it so you don't have to mess around getting it readjusted right.
Sandoval_broncosauria
