smell going up hill only
tiredbronco
i have a 91 5.8l with 153000. miles. it runs good, idles good, shifts good, but when i go up a hill, i can smell somehting , i dont' have any leaks oil or water, the smell reminds me of when a firework explodes and you can smell the smoke, thats what i smell. can you give me some things i could check?? thanks
Maddog
I have a similar smell to mine. No fluid leaks either.. I think it might be an exhaust leak or exhaust coming in through the body somewhere. As to how to find and treat it i'm not that far along yet. Sorry.
broncguy101
If your tailk pipe moves up and down and your body is some what rusted just get yourself a turn down pipe for a quick fix.
What you are smelling is most likely the cat loading with extra exhaust components, most likely due to either being clogged, or not getting air from the air pump.
T
tiredbronco
26090[/snapback]
what do i need to do about this problem???
26096[/snapback]
If the Air pump is functioning, then make sure that the air is being pumped to the cat. The proceedure is a bit long. I'll photograph the pages in my shop manual if you like but not tonight. Then if that is working correctly, you most likely need to replace the cat, especially if it is real old.
eholt80
