Shotgunning parts
bluesman17
Spam Terminator
South Bend, Indiana
Whenever its warm out, say 85+ my truck will get a hesitation that wont go away until about 15mph and until then its running like ***** chugging, occasional backfire. I think its the egr valve. Anyone agree or think it could be something else?
second problem in the winter my truck has a rolling idle and usually stalls out (kind of ruins the usefullness of a remote starter) only codes pulled from it where a transmission code (which im ignoring at the moment) and throttle position sensor out of range. any help is appriciated.
Grant
bluesman17
bluesman17
Spam Terminator
South Bend, Indiana
yeah the tps didnt do the trick and i just put a new o2 sensor in a little less than a year ago, so im going to try the idle air control thing then ill go to the o2 sensor. thanks for the input though
baumbr
Heber City, UT
The 300 I-6 in my '80 had similar problems. Turned out that the screws holding all the various levels/sections of the carb together had worked loose. After a proper snugging things seem to be fine.
4x4ever
Edmonton, Alberta, Canada
I had that problem in the winter, all I did was change the spark plugs and adjust the carb to lean it out a bit cuz it was running to rich. I also changed the distributor plugs and it seemed to make a difference.
eholt80
