Rear Window
noahsdad
So Cal
OKay so got my new engine up and running after only 3 days of work. This i sof course only 2 weeks after figuring out the other motor . So you guys know how it goes with these things first day I drive it back to work and that danged old back window motor is slipping. I tightened all the bolt and all so is there a rebuild kit for the motor or just replacement be my only option. Also does anyone know of a good place to buy these motors My passenger window is broke too but i dont care about that one I need my back window to get inside that area during camping trips
Local auto wreckers. Or try Broncograveyard.com
Just a note, might be an option for you, the Ford side windows use the same motor. If you use one the only difference is the wiring harness will have to be lengthened. You can get rebuild kits as well.
Coastersfwb
