Rear Seat
Davo
Carthage, TN
I bought my first Bronco but it does not have a rear seat? Any suggestions on what to about finding a rear seat? Thanks
As Ron advised;
http://www.mypartshop.com
Select All Parts
year, etc, then FORD TRUCK
Here are some returns for zip code 37030 (I used info you provided in your Profile)
95 BRONCO Seat, Rear
TAN LEATHER 0 030359
$200.00 114 Call Davis Salvage
606-528-3951
800-442-7876
701 SW 20th Street
Corbin KY 40701
2DR-XLT GRN TAN LEA BENCH 103 110038
562947 0.0 $150.00
502-361-2629
800-828-1075
Baird Auto Parts
Donald, Keith, Barry
502-361-2629
800-828-1075
8809 National Turnpike
Fairdale KY 40118
TAN CLO 0 051207
12438 0.0 $75.00 135 Call Davis Auto Parts
423-626-3438
877-671-3438
etc
yw
GL!
BTW from my 96 Bronco Workshop Manual = to your year
The Bronco has a fold-down rear seat. A rear seat back release latch on the lower right side of the rear seat is lifted to unlock the rear seat back frame. The rear seat back frame is folded to the cushion. A rear seat back release latch located at the center rear seat cushion frame (63160) is lifted to unlock the rear seat cushion frame from the floor-mounted rear seat back latch striker (62440). The rear seat cushion frame folds forward to provide a flat storage area.
All folding seats have a rear seat back release latch designed to hold the rear seat back frame in the normal position.
The rear seats can be folded down to gain access to the storage compartment.
If the rear seat back frame will not latch into position or the rear seat back release latch will not unlock, remove the side shield and/or remove the rear seat back cover (66600) far enough to inspect the rear seat back release latch. Replace defective components of rear seat back release latch.
See attached 96Rear SeatBronco thumbnail for Parts diagram
Item Part Number Description
1 55929-S2 ***** (2 Req'd)
2 98605B28 Plate, Rear Seat Cushion Scuff (1 Req'd) (LH Side Only)
3 613A38 Rear Seat Back Frame
4 387871-S2 Bolt (4 Req'd)
5 383493-S2 Washer
6 67412 Latch Assembly — Rear Seat Cushion
7 604K22 Rear Seat Cushion Torsion Bar
8 N804266-S2 ***** (4 Req'd) (RH Side)
9 385329-S2 Bolt
10 60514 Rear Seat Back Pivot Bracket (1 Req'd) (LH Side Only)
11 387871-S2 Bolt
12 383493-S2 Washer
13 111B42 Rear Floor Pan Opening Cover Plate
14 62440 Rear Seat Back Latch Striker
15 387871-S2 Bolt
16 378444-S Plug
17 67438 Check Spring
18 67440 Check Spring Retainer
19 63160 Rear Seat Cushion Frame
20 382552-S100 Washer
A — Tighten to 54-81 Nm
(40-60 Lb-Ft)
B — Tighten to 16-24 Nm
(12-18 Lb-Ft)
C — Tighten to 18-27 Nm
(13-20 Lb-Ft)
Removal
Remove rear safety belts. Refer to Section 01-20A.
Unlock rear seat back release latch (61382).
Unlock rear seat cushion latch assembly. Fold seat forward.
Remove rear seat cushion pivot bracket bolts.
Remove spring plug buttons. Remove spring bolts.
Remove the spring, washer and retainer from the rear seat cushion pivot bracket (60520).
Remove seat assembly from vehicle.
Remove screws attaching rear seat back frame (613A38) to rear seat cushion frame (63160).
Remove the rear seat cushion pivot bracket.Remove the torsion spring from rear seat cushion pivot bracket.
Remove rear seat cushion frame from hinge pivot pins in rear seat cushion pivot bracket.
Remove rear seat cushion frame.
Installation
Follow removal procedures in reverse order.
Remove the damaged bolt for the anchor reinforcement and discard. Install a new bolt with the same part number as indicated.
Tighten screws attaching rear seat cushion pivot bracket to rear seat cushion frame to 16-24 Nm (12-18 lb-ft). Tighten screws attaching rear seat cushion pivot bracket to rear seat back frame to 18-27 Nm (13-20 lb-ft). Tighten spring bolts to 54-81 Nm (40-60 lb-ft). Tighten bolts attaching rear seat cushion pivot bracket to floor to 54-81 Nm (40-60 lb-ft). Check the seat for correct operation.
Safety Belts, Rear Seats, Bronco
see thumbnail 96Safety BeltsRearOutboardBronco
Retractor and Tongue
Removal
SPECIAL SERVICE TOOL(S) REQUIRED Description Tool Number
Safety Belt Bolt Bit (No. 50 Torx®) T77L-2100-A
Remove shoulder strap guide cover. Remove the upper anchor bolt using Safety Belt Bolt Bit (No. 50 Torx®) T77L-2100-A.
Remove quarter trim panel. Refer to Section 01-05.
Remove the retractor anchor nuts from rear safety belt retractor and tongue and lower anchor bolt using the Safety Belt Bolt Bit.
Remove the rear safety belt.
Installation
Check sealer around floor anchor bolt holes and, if required, add Ford Caulking Cord D6AZ-19560-A or equivalent meeting Ford specification ESB-M4G32-A.
Install and tighten anchor bolts to 35-45 Nm (26-33 lb-ft).
Check the restraint system for proper operation.
Safety Belts, Rear Outboard, Bronco
Buckle End, Bronco
see 96Buckle EndBronco
Removal
At the back of the rear seat, remove the anchor bolt for the RH or LH safety belt buckle end, as necessary.
Remove the RH or LH rear seat cushion belt shield insert as necessary.
Feed the buckle end assembly down through the seat cushion and pull it out from the back before anchoring it to the floor.
Installation
To install, reverse the removal procedure. Tighten the anchor bolt to 35-45 Nm (26-33 lb-ft). Check the restraint system for proper operation.
Utahstroke
