rear hard top hardware & 3rd Brake light issues
Bngeejmpr
Hi there !
I have a 1993 Bronco that I need the hardware to attach the rear top advise on best place to purchase? 2nd question: 3rd brake light wiring? Former owner ripped the wiring out trying to find replacement any leads ?
Yo
As Shaggy advised.
See this Camper Top Removal w/Tool List, & Security Torx® bolt replacement w/Metric sized bolts (5 8x70mm 1.5 Pitch Metric Bolts & 12 8x45mm 1.5 Pitch Metric Bolts) 92 - 96
Source: by Froggmann (Ken P)
Camper Top Trim Parts Break-Out Diagram w/nomenclature; "...78-91 use 17 self-drilling oval-head 1-1/4" phillips screws with captive countersunk washers to retain all the trim pieces. 6 on each long trim, 2 on each short trim, & 1 on the small center joint cover. 92-96 use 5 screws as above for the short trim & cover, 6 color-matched pushpins on each long trim, & 2 plastic pushpins on each rear corner trim..."
Source: by Ford via Steve
➡Was speed control, if equipped, recall work completed by a dealership? Call local dealer or register and view status speed control, if equipped, recall work completed by a dealership. Call local dealer or register and view status @@ https://owner.ford.com; or @ https://vinrcl.safercar.gov/vin/ ... have VIN ready.
The affected vehicles were previously repaired using a wiring harness that is not compatible with the vehicle circuit polarity. As a result, the fuse is located in the output circuit rather than in the intended input power feed circuit, and may not offer the intended protection in the event of an electrical short to ground. This could result in an underhood fire. Dealers will install a new wiring harness, or replace the mating electrical component. east302 provided following for his 93 "I found the recall information on alldata...didn't know it was even there so that's a plus. Mine has the updated harness with two fuses instead of one, so it looks like the recall was addressed correctly."
Use this guide by jowens1126 @ https://www.fullsizebronco.com/forum/23-technical-write-ups/457065-93-94-96-cruise-control-recalls-repair.html#post6530073
Note that the 93 recall is different that the other years.
Here is the 1993 Bronco Dealer Brochure in Google Drive @ https://drive.google.com/file/d/0B-xGWnnLeWl6cGFMTDNNcGprQTA/view
1993 Bronco Dealer Training Video via silver70 @
1993 Bronco, Venezuela Commercial @
If this site recovers from a little nap, sign up for free registration for some wiring diagrams (86 through 96) and Technical Service Bulletins, (80 through 96), same as by Ford @ BBB Industries- Premium Alternators, Starters, Power Steering Products | TSB's & Wiring Diagrams
Bngeejmpr
Thanks Shaggy ! I do have the 3rd brake light itsef... just no wiring to it.. any ideas ?
Yo Shaggy,
We'll find out if he asks for it.
I can get the routing if he needs it and possible yards that may have it
Bngeejmpr
Thanks for all the info ! Definatley need the harnesses.
Yo B,
I don't have a source for the harness, so in case it may have to come from a yard queen, but for a YARD SEARCH on-line, I use;
https://www.hollanderparts.com
A yard that uses Hollander Interchange can search other yards and have it shipped.
The Hollander Interchange provides auto recyclers and auto collectors, rebuilders, and others with the easiest and most comprehensive solution for identifying interchangeable auto parts..." See their yard Directory @: https://www.hollanderparts.com/SellerDirectory
Can select certain parts[, /B] including some at Canadian yards.
Has Vehicle Pics for some vehicles
My search just now didn't get resukts for
 : 1995 >Ford > Bronco > Lights > High Mounted Stop Lamp > Alternate High Mounted Stop Lamp
But this search possibly did; Search: 1995 >Ford > Bronco > Electrical > Lamp Wiring Harness > Al"ternate
Lamp Wiring Harness
or
http://www.car-parts.com/
Has Vehicle Pics for some vehicles incl. interior/dash, back seat, front & rear and engine bay
Bronco Used Part Search @ https://www.partshotlines.com/parts/ford/bronco/ with source, cost, yard and phone #
Concord Spare Parts @ https://www.concord-parts.com/
732-374-3872
[email protected]
http://www.picknpull.com
This is a Company name w/yard locations in various states
Can NOT Select certain parts
B&R Autowrecking, in CA, WA, NV, OR. "We have a fleet of over 60 trucks that deliver to business addresses all over Oregon and Washington. Outside of Oregon and Washington, we have daily shipping services. Contact Us for a quote."
"Will ship to their closest yard for $50 flat" by StemCellResearch", 2019
http://row52.com/Search
AND Want a Part? It's Easy...
1. You create a Parts Wanted Listing.
2. Parts Pullers respond with offers.
3. You pick the best one.
A Parts Puller gets the parts you need.
For obsolete parts by Ford long version pn:
http://www.partsvoice.com/
http://www.rearcounter.com
http://www.greensalescompany.com
https://nospartsltd.com
And by a search function;
https://autopartsobsolete.com/truck-ford/
fred tyler
