rear gears
WileE7
How can i find out what the rear gear ratio is in my bronco i have 90 full size eddie bauer w/302
If I had to bet I would say 3:55 but the only way to really tell if you8 dont know the history of the truck is to remove the rear cover and look on the ring gear somewhere it is stamped in there ford 8.8 and a set of numbers like 41-10 which is 4:10 I cant remember the 3:55 ones right now but you just divide the big number by the small number and thats your ratio :D /emoticons/[email protected] 2x" width="20" height="20" />
swampthing
there should be a tag on the rear and on the tag it will have numbers...if it says "3 L 5 5" its 3.55 gears with stock locker....if it says 3 O 5 5 same thing but open end
WileE7
WileE7
is it the same for the front?
if the rear is 3.55 then front is 3.54
John Eversoll
Hello there buddy, you can look on the rear end for the tag" it will be stamped what gear you have.
Coastersfwb
