Rear driveshaft
Burns
Royersford, PA
Doing the u-joints on my 89's rear driveshaft. So far, smooth going. Until I hit this spring in the front half, inbetween the 2 u-joints. My questions are what is it, what's it do, and do I really NEED it? :p /emoticons/[email protected] 2x" width="20" height="20" />
92broncomann
Coolidge, Arizona
I believe it helps keep everything aligned under stress and it applies pressure on that center pivot ball in the CV, not sure if you truely need it, but when i did mine i just put everything back the way it was, who knows if it would cause any problems without it tho.
Burns
Royersford, PA
Did the joints, found a spring that matched what came out. Still got the noise, but the joints DID need replacing anyway. I think the next step is cv joint its parts, then a rebalance.
The centering spring and ball in the Double-Cardan joint keep pressure on the inner yoke for the outer u-joint. It can be a PITA to re-assemble everything, but I would not leave any parts out. If you lose one of the parts, you can get a repair kit for about $18-$20 fro mthe parts store. There may be a recent thread on the DC-joints, too. JSM84
http://broncozone.com/forums/index.php?sho...le-cardan+joint
Burns
Royersford, PA
Sweet, thanks JSM84. I think my best bet is to get a new cv joint, a small parts kit and rebuild it. I have a horrid vibration and clacking noise, from prior experience with said symptoms I did the joints. Not this time. Now all I need to do is get to a computer and read those manual pages and not do this on my phone haha. :p /emoticons/[email protected] 2x" width="20" height="20" />
kyleh01
