Burns
Ford's famous floating gauge:
Anyone else have the problem where, driving around for a bit, you see your at maybe half a tank, look again 10 minutes later, it's at about 3/8's tank, then again in another 10 minutes, it's up to 5/8's tank? I know for a fact I have the "electric floater," because I've had to replace the fuel pump and fuel tank itself. Is there anything that will give me a solid and stable reading on my gauge?
Dashboard woes:
I'm getting tired of the old stock dash instruments. I'm looking for something a little brighter at night, a little easier to see, and maybe, just maybe, digital. I'd also like to add a gauge or two for some extra measurements. If I get a full blown instrument panel kit plus whatever installation kits and wiring kits I'll need, is the panel that hard to rewire/replace? I don't want to start tearing into it and then all of a sudden hit a brick wall (figuratively) with my daily driver.
And I know this has probably been asked a million times, but I can't for the life of me find an answer I can completely understand. I apologize if it seems/is redundent.
The straight axle conversion kit on Jeff's Bronco Graveyard lists it as a complete kit, but I've heard that it's only a "part 1 of a full kit." Is that all I'd need? And if so, would I need to get a rear lift kit if I were to get the 8" front end conversion?
I'm trying to avoid sounding like I have only a small clue as to what I'm doing, but I figure best way to learn is to ask who knows and who's done it.
Thanks for the help guys (and gals!) >
Dashboard woes:
