Arc Light
- Joined
- Sep 5, 2007
- Messages
- 4
- Reaction score
- 0
I just got my rig back down on all fours, test drove it around the block, it pulls to the side (which side I don't remember), the steering wheel is off centered, and the front end alignment is way out of whack. Am I correct to assume that this is normal after a lift install? I also replaced the radius arm bushings and the pivot arm bushings, replaced worn out wheel bearings, and tomorrow it goes to the Ford dealer to have the ball joints replaced and aligned. After doing all that work, I expected the alignment to be out, but not out in left field.
