pull when braking
Ryan S.
I have a 89 bronco 4x4 I put new pads and brake lines and driver side caliper bc the seals were leakn in it, but it still pulls to the right under normal braking any idea what else could cause this???
When you put new lines in, what method did you use to bleed them? Did you put in all new lines front and rear?
Hey Ryan,
Brake repairs should always be done in pairs, (both left and right side).
If you replaced only the right side caliper that could be the cause.
Pulls can come from the rear being out of balance, or even the tires.
Good Luck
Coastersfwb
