preventing rust on 94 bronco
broncosam43
upstate new york
i am replacing the tailgate on my 94 bronco and i am also having the wheel wells replaced i was wondering if anyone has tried anything to stop the rust from coming back the truck is ziebarted but i thought of tring to put something between the wheel well and the inner wheel well because there is a gap there and easy for salt and dirt to get in there any ideas on how to prevent the rust that would be great thanks Sam
yo Sam,
Since there is a gap, because the two are joined by spot welds @ the factory, I Guarantee there is some outstanding rust pockets inside; at the outer 1/4 panel's wheel well lip where it bends inward and up at the top of the wheel well inner housing.
We bought our 96 New and kept the lips clean; overtime we washed it (weekly by hand, even in winter) we cleaned the area well.
Up until last summer, we cleaned-up minor rust on lip that we fully believed was caused by stones; last summer when I decided to remove the wheel well moldings, yep! Hello Mr. Rust Holes.. Mr. Rust was laughing at me; he said he was hiding under the molding for years!
I got my Dremel out and lost about half of the lip on the passenger side... nearly all was gone around most of the blind rivets.
When I get patch panel someday, I'll use Body adhesive (& some blind rivets to hold the patches tight to the 1/4 panel skin at top and sides of the patched area) to attach em to the 1/4 panels instead of welding and spot welds.
GL
AdamDude04
Really the only true way is to gut the whole dang truck.
I'm giong to do that when I install my new motor, though I'm going to tackel the areas I can get to in the meantime. Grinder/dremel and remove all the rust and old paint. Then bedliner EVERYTHING.
Best thing to do, is do two jobs at once: for example, if you need/want/should replace the fuel pump, and decide to drop the tank, make a 2nd day of it just cleaning everything you can reach with the tank removed. Then coat it to protect it. Only worth it, if you plan on keeping the truck forever tho..
