Power windows?
EvlFaust
Las Vegas
I have a 95 Bronco that has manual crank windows right now. I want to convert to power windows. The idea that I have is to replace the door panels with panels from a 95 Bronco that will accept the stock switches. Then I plan on changing out the manual window regulator with a power window regulator.
The question that I have is will all of these items bolt in. I noticed that the power window regulator sits at a different angle in the door than the manual one sits at. I haven't really had a chance to see if the door is meant to fit the power ones even though it came stock with power regulators.
Also does anyone know where to find door panels for a 95 Bronco (besides the junk yard), all I am able to find is door panels up to a 91.
Thanks
If your doors are stock OEM doors they will accept either regulator. You will probably have to drill out a couple of rivets which can be replaced with the same type rivet or small bolts. Have you tried LMC truck for panels? http://www.lmctruck.com
E
EvlFaust
Las Vegas
Thanks for the info. I figured that was the case but wasn't too sure. I have checked LMC, thats where I am getting the regulators and door switches from. It seems like everywhere I usually get parts from only has door panels up to 91.
Thanks again.
Yah, I have looked around the net and all I have found so far is the same thing you did. I think you are stuck with either an auto recycler or Dealer. You might try contacting a body shop and see where they get their parts from if one was damaged in a wreck.
