Power steering pump question
90BroncoXLT
Hi,
I took the high pressure hose off the p/s pump and the fitting is much larger than the new replacement hose. Now the old fitting looks like it might be some kind of adapter, but I can't seem to get it apart using as much penetrating oil+brute force. Is this fitting available, or do I need to replace the pump?
Thanks.
muddog
Indianapolis, IN
if the pump is OE then you might as well replace it too. it only cost about $30 without the reservoir and $50 with reservoir plus $20 core. and there easy to change
Coastersfwb
