Power Mods?
mudunit77f250
ok, going to drop in a 400 and it will be in my mud truck (36x12.5x16.5 TSL's) ive already got long tube headers, dual exhaust ready to go. so what are some other mods i should be looking at for some good HP/ torque gains. what style air filter assy do you guys reccomend/ like?? i want to get rid of the restrictive stock housing. I just saw the MSD ignition post and would atleast buy a new coil to try and keep the spark hot. i would love to do a cam, but i def dont have the money for that and wont for a long time.
Txquadhunter
N. Texas
the 351m/400's love to breathe, Since ya got header end covered. look around for a good 4bbl intake. it'll really wake one up. I see good used 4bbl intakes quite a bit cheap.
78mojavebronco
HOLLY CARB. K&N FILTER. Not the cheapest but it's the best. Buy it once and be done. holly makes a very nice carb, The truck avenger like the street avenger but made for off road.
G
Guest
Guest
my only concerns about the 4barrel carb is that on inclines ( powerlines) they are more prone to stall out. the 2bbl is "better" b/c they have a larger flaot bowl, and its harder to lose the gas from the float bowl...... will that truck avenger carb fix that issue? [-o< i dont want to be stalling out climbing small rock ledges.... and i dont have a manual choke either, so i cant set the choke open a lil bit to keep it running in the tough spots. i plan on buying one of those 14" round filter housing assemblies..... $-)
4xfan78
Georgia, augusta
I've got 4 barrel carb on all my trucks, havent had the stall problem with mine. I would recommend NOT using holly carbs(personal opinion) I recommend edelbrock carbs.
4xfan78
Georgia, augusta
If you are going to own a holley buy 2, this away when one breaks you have a spare in youre truck already.Then you can rebuild the other and start over again.
78mojavebronco
Ya the holly truck avenger is built for off road never had any trouble.
as for the edelbrock/carter always had trouble. with high speed off road.
very hard to fine tune.
But thats just me.
:D /emoticons/[email protected] 2x" width="20" height="20" />
freak
Indiana
As far as the Edelbrock's go I've done quite a bit of work to mine and finally got the right combo.It run's like a ***** ape now.
Billz4x4z
Carnesville,GA
Definately a 4bbl intake and carb.Don't go over 600cfm with a stock engine.I run edelbrock without any problems.
Just my thoughts
Bill
M
mudunit77f250
ok, ive weighed some of the other views that ive gotten, and it sound like, one of those if it aint broke dont fix it type things, so heres my plan, wheel it a lil with the stock 2bbl, and if i dont mind Stall issues that i have wheeling the 2bbl, then stick with a higher cfm 2bbl..... im going to keep an eye on the truck avenger carbs as a guy on NEOW is putting one on his 360 once he puts it in, and he said he would keep me updated on how it works for him.
rlnbreloder
Blue Springs, MO
Just FYI....
I noticed you were on a budget, but I would like to add that I just got done rebuilding my 400 and the only new parts I actually bought were the pistons, rings and bearings....I got everything else off of EBAY (mostly used stuff). I've got 10:1 Badgers and a used cam (paid $20 for cam and lifters), I've got less than $500 in the motor (including honing, new cam bearing, and cleanup on block/heads). These motors come from the factory with (arguably) the best flowing heads to ever come out of Detroit....the only thing they need is a boost from 7.9:1 compression and MAN WILL THEY MAKE TORQUE AND HP. They've actually got the longest stroke of any Ford motor ever made...
rlnbreloder
Ziggy
Riverside, Ca
I recommend installing the Edlebrock intake as well. It will take both the 4 BBL and 2 BBL carb, so you have the option of going back and forth. I have one on my 79 351M and it gives better performance through all bands of power.
McGuyver
I did a complete rebuild of my 351m with an eldebrock performer intake & 600 cfm carb ,& new cam (nothing too radical) unbelievable how much better it runs. easier on gas than the 2bbl if i stay out of it. $ 500-600 for new parts.
pimpa shrimp
the Edelbrock is ok i gess the holly same ok but theres better what im getting is a beary grant carb. the compreashon is a big thing, stock its 8 to 1 if u bring it up to 9.5 to 10 the mod would run great
muddrivermike
Texas Arp
Eldbrocks are for people that cant work on a holley.If you want better throttle response go with a holley.Ive had eldbrocks on other trucks of mine and they ****!The only thing they are good for is better fuel mileage since you cant get any performance out of them.As for keeping a 2bbl on the truck,,,For what?? A 4bbl will still act as a 2bbl as long as you dont make the other 2 bbls open up,as in flooring it sucking down gas,But the option will be there if you need to use it.I have an eldbrock intake ,,Holley 600 single feed electric choke,Ive never had any problem with stalling on some off camber situations.I went with a DUI distrinutor in place of the stock one,Ive noticed the truck runs better and has a little more power.I went with the Accel 10.8 mm wires,they are the thickest wires with the least resistence,And for plugs I used those E3 plugs.With all this It made a difference,especially when out in the mud. :D /emoticons/[email protected] 2x" width="20" height="20" />
Val
