CSM_Bronco
so here i was testing the depth of some small water hole...no big deal...went slow, wasn't higher than the tire even (31")...well...the bottom of it was nice and sturdy ground...very solid...no rocks...nice and smooth...
now to my problem.
i was being stupid and hit it with some more speed...to try to get some good footage...anyways, the hole was about 30' long...not that deep...i got about 3/4 of the way through it when the engine died...at this point the engine was even out of the water...well, i pushed my newly installed/rigged push button ignition and all i got was the starter engaging, and then stopping...engine wouldn't turn...got the starter checked...its just fine...i think i siezed the engine or something...
there is a good possibility i got some mud water in the TB...the engine was running cool and strong before hand...ran like a beast...i tried turning it over manually (crankshaft) and i got nothing...i'm going to try to pull the plugs tomorrow and see if it turns over...hope for the best...
if that does not work i've been told to spray some WD40 down each cylinder...an hour or so later follow it up with some oil...and then just let it sit for a day or two...
i heard it could possibly be a wedged cylinder...i tried turning the crankshaft both ways...and was told if it was wedged...it would unwedge itself turning it in the opposite direction...but like i said...i hit nothing hard...the bottom was smooth with no sudden changes...
any opinions would be greatly appreciated
now to my problem.
