Parts Question
RebBronco
Ok y'all what in the **** is "shift soleniod 2"? This is the part that my code reader keeps throwing and well I need to know what it is and where so as I can replace it.
Info on the truck would be *really* helpful, maybe indicate in your signature just which vehicle you're refering to and what you *currently* drive. I know the 4x4 shift solenoid is behind the glovebox on the right hand side. It's a small blk box looking thingie that clicks then you press the dash buttons (or it *should* click anyways, that's the solenoid actuating)
yo; am guessing it is da 90 Bronco?
EDIT; also ck my reply to your other Q in this forum...
it is in the valve body's solenoid "pack"w other solenoids .. drain fluid, pull da pan;
Parts Diagram w/valve body location by transmichigan.com
Look @ valve body; here is a diagram of the solenoid pack
http://www.artcarr.com/merchandise/technical/18/265.acpp
see page 4
Solenoid Pack Removal by stangmata
The entire solenoid body would have to be replaced ($170.00 or so). or get one from a re-builder
http://stellargroupinc.com/images/Parts/OE...L%20(Large).JPG
First check for;
a break in the wire harness for that solenoid
bad/corroded connection there or at @ transmission connector
Test it (by Steve83)
"Shift Solenoid 1, Shift Solenoid 2, Torque Converter Clutch Solenoid, Coast Clutch Solenoid
> Set ohmmeter to 100-200 ohm range.
> Connect positive lead of ohmmeter to the appropriate vehicle power (VPWR) jack for the solenoid being tested.
> Connect negative lead of the ohmmeter to the appropriate solenoid (shift solenoid 1 [sS1], shift solenoid 2 [sS2], torque converter solenoid [TCC], coast clutch solenoid [CCC]) jack and record resistance.
Refer to following charts for values.
If out of specification, refer to
RebBronco
RebBronco
Thanks miesk5,I thought that what it was.Thanks again.
yo; am guessing it is da 90 Bronco?EDIT; also ck my reply to your other Q in this forum...
see page 4
First check for;
eholt80
