oil seal for rear axle 8.8
USMCBroncO6672
Good Evening Guys.
has anyone changed the seals on their truck could yall give me a step buy step
U
USMCBroncO6672
outer seals because i have fluid leaking out of my drum brake and it is not brake fluid
You have to pull the axles and you will see the seals sitting in front of you. Pry them out with a ***** driver and gently tap the new seals in place. With new oil, wet the rubber surface prior to installing the axles.
mbtech2003
cape cod, mass
hows your bearings as well??? check the axle when u remove it if their is any marks or scoring like mine was, u will need new axles and bearings. u will need to remove the rear diff cover, drums, and the spyder gears then slide out the axles. if u need new axles then use theese... http://broncograveyard.com/bronco/i-32362_...ls___studs_.htm
that is of course if it is the 8.8 inch rear end. what year and engine is it?? i also bought new brakes from them as well because my rt side axle bearing sh$% the bed and the seal leaked out on my rear shoes.
i just bought them and installed them in my truck. Really good deal for the money, they come with axles, bearings, seals and , wheel studs!!
On the ground then it will probably take about 4-5 hours depending on your skill level. u will need a slide hammer or puller to remove the bearings from the axle housing.
Coastersfwb
