Oil pump change
nagodwin
I am going to change my oil pump on my 78 bronco, with a 400 engine. Has anyone done this before? how hard is this? whats the fastest way and easiest?
86Bronco
Colorado Springs
just drop the pan off, you can do this all this with the engine still in her. Pull the pan down and there she sits, 2 more bolts and its out. Make SURE that you put a new drive shaft in it and make sure its splined with the dist, or there will be major problems
figjeti
