Now What!!?
blackbetty83
monroe,Ga
My 83 ford bronco will not start from the ignition it will only start if i jump it off from the selonoid. I have replaced the ignition lock and key, starter, voltage regulator, selonoid, battery cable, and the starter switch and connection. Can someone tell me what else it might be.
Roadkill
Killeen, TX
Have you checked the neutral safety switch (automatic trans) or clutch switch if it's a manual transmission. Could be broken or out of adjustment.
Coastersfwb
