neobaptist
I have a 1990 Bronco 2 auto, 4wd, 2.9L with a noise issue. If I get on it hard from the sitting position or if I am on an incline and get on the gas my Bronco makes a grinding type noise and it does vibrate a little. Someone told me it was my U-Joints needing grease but on my Bronco 2 have the OEM CV-Joints. I haven't delt much with CV's and am not sure what exactly to do.
Does this sound correct that it is my CV's making the noise? I thought at first it was my oversized tires but they aren't even coming close to rubbing. Is it best to grease them, or just replace the CV? If I do need to grease them where would it be located? I can't seem to find it and haven't found anyone that can tell me wether or not the 90 Bronco 2 factory CV's even have one or not.
I don't want to switch to a U-Joint because it is my daily driver and I do get it up to high speeds from time to time and have heard the conversion would cause a lot of vibrations.
Other than this my Bronco 2 run's like a champ and like I said as long as I don't get on it to hard it doesn't make the noise, but I'm sure that the problem still needs corrected.
