New waterpump still leaking
Dltnjest
Cedar Rapids, IA
So I am getting fairly irritated with my new buy.
I bought this Bronco for $1500 thinking it would be a good time investment, yet im almost at 1750 lol
Anyways, I put a new waterpump in it the night after I got it. It was leaking everywhere out of the run off drain? If it has a real term.
So I put the new one on, gasket, bolted it up, didnt see any problems until I open the hood a week later.
Everytime it gets 2500-3000ish it sprays antifreeze everywhere. You can see it in the middle and lower right underside of the hood. But not when I dont rev it up. Any info on this? I bought it from Autozone, I can get the box if needed.
D
Dltnjest
Cedar Rapids, IA
Yeah, it leaks out of the drain valve thing - im not sure of the actual term
Then it comes downward, hitting the fan, giving it a nice spray to the right side of the hood
"It was leaking everywhere out of the run off drain? If it has a real term."
I'm thinking you're talk'n about the radiator overflo tube.
This would NOT be a waterpump problem, but a clogged radiator issue. At the very least, a faulty radiator cap.
Is the temp gage reading high..?
An engine block & radiator flush is easy but, even at that, you'll likely need a radiator re-build, or a new radiator.
May also be a good time for hoses & a new thermostat.
