need parts
broncodriver33
Palmyra, Pa
flipped my 86 on the passenger side :(( in need of oem parts good used parts will do fine also. I am finding that the moulding that is above the wheel arch is hardest to find not the ones on edge of opening but above. see pic that i attached of my beauty. I also put a post in classifieds any help would be appreciated. please helpbronco.jpg
broncodriver33
Palmyra, Pa
I was just a little sore this week no passengers. Just one of things when your trying to avoid another sliding vehicle on ice and i did but i got the blunt of it and they just kept driving. thanks I will check into those sites i didn't see the arch moulding i need on jeffs but will check again.
Krafty
Ontario Canada
the link for broncograveyard that miesk has provided take you right to the parts you need, also lmc truck carries everything for the bronco's as well, but with broncograveyard we get the 2% discount.
broncodriver33
Palmyra, Pa
so the ones I see there on that link are the correct ones i was worried they might have been the ones that fit on the edge of wheel well. i was going to call them to make sure and how do we get the discount
yo B,
YW!
Here it is from JEFF's
Wheel Opening Trim Quarter Right, 80-86
# 35183
New
1980-86 Ford Bronco
1980-86 Ford F100, F150, F250, F350
Rear Right or Pass
Price: $25.00
Wheel Opening Trim (Set Of 4), 80-86
# 35180
New
1980-86 Ford Bronco
Set of 4
Price: $90.00
http://broncograveyard.com/bronco/i-35180-wheel-opening-trim-set-of-4-80-86.html
Hopefully that is it
If it is and you buy the new trim, let us know here and we will remove your request from the Classified section
Krafty
Ontario Canada
the item with the same year range as your bronco will be what you are looking for.
to get the discount you put in BZMEMBER in the coupon code area then in your order as a note include your username
Coastersfwb
