Need owners manual
Svlack
Las Vegas
Hello. I'm a new 95 owner with a 351. Om trying to find a owners manual. Can anyone help.
Yo Svlack,
As Skitter advised and the 96 Manual is similar to the 95. It's not the exact year, but close enough that it'd be a pretty good reference, especially engine transmission, 4 Wheel Drive, instrument panel gauges, warning light, buzzers, chimes, jacking, etc operation.
In 96 manual, "the OBD II system is designed to check the function of the vehicle’s powertrain control system during normal operation. If an emission problem is detected, the Check Engine Warning Light (in the cluster) is turned on."
Iggie that Powertrain On-Board Diagnostic II (OBD II) system because your 95 uses the ELECTRONIC ENGINE CONTROL (EEC IV) system that performs same function the Check Engine Warning Light (in the cluster) is turned on when a problem occurs.
Ceck e bay
Here is the 1995 Bronco Dealer Brochure
1995 Drivetrain, Powertrain Service Manual
1995 Bronco Drivetrain, Powertrain Service Manual - Google Drive
1995 Body, Chassis Service Manual
1995 Bronco Chassis, Service Manual - Google Drive
To switch between folder list & grid views, click the button to the right of the "DOWNLOAD ALL" button in the upper right corner of the window)by HawkDriver
Also, if just purchased, was speed control, if equipped recall work completed by dealership? Call local dealer or register and view status @ Welcome to Ford Owner | Official Ford Owner Site; or @ Recalls Look-up by VIN (Vehicle Identification Number) ... have VIN ready.
fred tyler
