Need help!!!
fromdaattic
I have a 91 ford bronco and the CV Head Ball and Spring have worn bad besides the ball and spring what else could be worn im trying to order parts and when i had it apart i dunno what its called the cup that the ball rests in was worn does that mean new drive shaft???
Billings Lee
Billings Lee
Portland, Oregon
well if u road hard, new drive shafts wouldnt be a bad thing. **** to birds with one stone... and possibly other birds down the road. >:)
F
fromdaattic
i know how to do the universals and all that im worried aboutwhat the ball fit into is that includeed in the rebuild kit? i dont want to spend 300 dollars for a new drive shaft
I have been beating my head on my keyboard trying to remember what that part is called, I totally know what you are talking about but the name is eluding me at this time.
You should get the parts in the D/C joint repair kit to take care of the worn seat. IF your driveshaft has that part welded onto the main shaft, you can have a driveline shop weld on the new piece. A used driveshaft will run about $50 if you want to take your chances that it isn't worn out either. JSM84
Coastersfwb
