Need Help
Blade
Guest
I have a 1986 F250 and the ring & pinion is bad. The proublem is all the listings for new ones are saying 10.25 inch ring and mine measures 10.5, is it that i'm measuring wrong or are they calling it a 10.25 instead of a 10.5? I'm also looking for a good set if you would know of one out there and who would be the cheapest on this new. 3.55 ratio
BLADE262US
Michigan
Hello a 1986 shouldnt have the 10 1/4 in it it should be a dana 60 . Is it a full floater or a semi floater ? If its a dana 60 and you know the ratio I may have a rear end for ya . Im in MI so if your close it could be picked up . :D /emoticons/[email protected] 2x" width="20" height="20" />
Val
