need help / break and turn lights
1funflaboy
fort walton bch, fla
i have a 1990 bronco. i lost my break lights and turn signals. i have already replaced the fuses, turn signal switch, and the brake switch. still nothing?? i still get the running lights in the rear. i have been trying to get this fixed now for about 2 months,and i'm about at wits end with this problem. if anyone can help me please do. if ya'll are anything like me i don't type to well so anybody is more than welcome to call i can be reached just about any time at 850-582-4868 thanks Sean
50joe
Trenton NJ
Did you replace the 4-way flasher? The left/right flasher is after the turn signal switch in the circuit, but the 4-way is before the turn signal switch, and it also over-rides the turn signals. The power runs from the fuse, to the stop light switch, through the 4-way flasher, then into the turn signal switch. Should be right on the fuse block, but it is the one in the back. The one in the front runs the left/right signals. You can even try swapping them around, they should be the same part number.
