need help . 88 Bronco 2 has no power no nothing
sublime88
I have an 88 Bronco 2 I got it a couple weeks ago I change the starter water pump and thermostat and starter solenoid ran fine. a couple days ago I went to the gas station ran fine got out to pay for the gas came back out no lights no power no nothing would not start.so I towed it to my house and I change the ground cable. I'm getting power to the solenoid but still no lights and won't start
S
sublime88
Nope it won't. It sparks when I cross them but that's all that happens . its the weirdest thing its like I don't have a battery no lights turn on or anything. Thanks for replying
Check he condition of your battery (-) cable.  Remove all connections, clean them (including the positive connections to the battery).  That includes the (-) connections to the engine block and frame.  Check the area where the lugs attach to the cables, if there is any corrosion, replace the cable.
S
sublime88
thanks for the information and the replies I fixed the problem there was a wire with a wire nut on it with some of the wire exposed and it shorted out and melted the wire right behind the windshield wiper fluid box but now when I turn the air conditioner on the amp gauge goes crazy
Fryman22
