Need Driveshaft information Help please!
A
AdamDude04
If I remember correctly, the driveshafts are fit with 1330 joints. From what I've read the 1310 and 1330 joints have the same cap sizes but center points are different sizes which plays into angle options..right?
On the 88/89 broncos, the drive shaft is held into place at the axle and tranny via U bolts. So for my case, I would assume if the 1310 and 1330 have the same cap diameter then they should bolt up with ease. But I don't know Jack about drive shafts so I'd hate to give this guy $40 and it doesn't fit..
The guy said the driveshaft was from a jeep. Dunno what kind.. However he says compressed it measures about 31" and fully extended at 35". This is what I got from broncograveyard:
Item #32408 - New
1988-89 Ford Bronco
A.O.D. Automatic Transmission
This is a rear driveshaft with u-joints at both ends.
Overall compressed length is 31½"
Overall extended length is 35 5/8"
Not sure 'bout "jeep" stuff on a FSB... :unsure:
"But I don't know Jack about drive shafts"
With your lack of knowledge., I recommend you talk to your local driveline shop.
That rear shaft has to be "right" .... :-B
A
AdamDude04
That's what I'm sayin. This looks identical to mine as both ends have exposed u joints which can be attached to the truck with u bolts.
I was going to just order a new one, but I need to save my money as it's going to cost me around 4k to move everything across the country. Bronco clunking bad now and I need a good temp fix until the move. At that point a new motor a paint and other things get a good improvement.
Well, Jeeps and FSBs use the DANA 44 rear end, so that should fit. The question remaining is will the Double Carden joint attach to your transfer case rear output yoke. If the measurements are the same, then most likely it will work for you.
"Well, Jeeps and FSBs use the DANA 44 rear end,"
Seabronc..... Are you sure....?
They (Jeep) went to a so called D-44 (front) when it became the Rubicon.
(not sure about the rear)
And doesn't the FSB have a corp. 8.8 rear & D-44 front.???
Some jeeps I've seen have a real skinny dr. shaft.... :unsure:
You are righ. I must have been half asleep :blush: I'd still think that if all the measurements are the same, it would fit. You are probably right Elmo, but if he doesn't work it hard it would probably work, he said it was only to be a short term solution. However Jeff's has them for under $300.00. http://broncograveyard.com/bronco?search=driveshaft
This is what Apache0715 was trying to do elsewhere;
Since he began it on 20 OCT 10, no one has added or confirmed any dimensions.
Dimensions, Rear; Overall Compressed & Extended Length (partial)
Source: by Apache0715
Stock Drive shaft Lengths
I would like to get a compilation of drive shaft lengths for people to reference. I have been searching and can't seem to find any information on it.
Can we get some posts of driveshaft lengths for your stock Fseries/Broncos? Front and rear, fully compressed and full extended. Transmission/Transfer case type and rear end type.
Determine the driveshaft length by measuring from the centerline of the front U-joint cup to the centerline of the rear U-joint cup.
Example
1987 Bronco 351/C6/BW1356/8.8": Rear (non flanged) - 28"/35" front - 20"/28" (THESE DIMENSIONS ARE EXAMPLES NOT ACTUAL)
I will post mine up the next time I am home. If you post up I will edit and place all measurements in this post for easy referencing.
Found some info (should have checked there first, www.broncograveyard.com (I stopped shopping there after my an order issue))
(does not state XFER case, I assume BW1356, if anyone has a discrepancy let me know)
REAR DRIVE SHAFT LENGTHS:
1980-87 Ford Bronco
1980-87 Ford F150
Overall Compressed Length 39 3/8"
Overall Extended Length 43 1/2"
1980-87 Ford Bronco
1980-87 Ford F150
Overall Compressed Length 35-1/2"
Overall Extended Length 39-1/2"
1988-90 4 Speed Manual Transmission 105 wheel base
1988-90 C-6 Automatic Transmission
1990 E4OD Automatic Transmission 300 6 Cylinder
1990 E4OD Automatic Transmission 351-W V-8
1988-96 Ford Bronco
1988-96 Ford F150
5 Speed M/T
Overall Compressed Length 37 1/26
Overall Extended Length 39 15/16
1988-96 Ford Bronco
1988-96 Ford F150
4 Speed M/T
Overall Compressed Length 39 1/2
1988-93 Ford Bronco
1988-93 Ford F150
A.O.D. A/T
Overall Compressed Length 34 3/4
Overall Extended Length 38 7/8
1990-96 E4.O.D. Automatic V-8
1994-96 4R70W Automatic Trans
Overall Compressed Length 41"
Overall Extended Length 45 1/8"
1980-82 Ford Bronco
Uses 1330 series u-joints
compressed lenght 30 5/8
1983-84 Ford Bronco
3 7/8 x 30 1/16 x 3 7/8in
1985-86 Ford Bronco
3 7/8 x 29 13/16 x 3 7/8in
1985-86 Ford Bronco
With C6 Auto
With 4Spd MT
3 7/8 x 31 5/16 x 3 7/8in
1987 Ford Bronco
With AOD Trans
1987 Ford Bronco
With C6 Auto Trans
With Manual Trans
1988-89 Ford Bronco
1988-89 Bronco
5 SPD M/T
26 1/2" collapsed
30 1/4" extended
1330 series CV
1330 series slip yoke
1988-89 Ford Bronco
Compressed 29 1/8"
extended 33 1/4"
1988-89 Bronco
NP 4354 SPD M/T
compressed length 30 11/16
1990-96 Ford Bronco
With 3 Speed Automatic Trans
With 4 Speed Manual Trans
Flanged type
overall compressed length 32 1/2
overall extended length 36 5/8
1990-96 Bronco
With 4 Speed Automatic Trans
AOD
Flanged type
overall compressed length 31 1/2
overall extended length 35 5/8
1990-96 Ford Bronco
Electronic E4OD
Flanged type
Overall compressed length 26 9/16.
Overall extended length 30 11/16
1990-96 Ford Bronco
With 5 Speed Manual Trans
Flanged type
- Overall compressed length 29 1/8"
- Overall extended 33 1/4
TSB 97-20-15 U-Joint Identification
Publication Date: SEPTEMBER 29, 1997
LIGHT TRUCK: 1990-1996 BRONCO
1990-1997 AEROSTAR, ECONOLINE, F SUPER DUTY, F-150-350 SERIES, RANGER
1991-1997 EXPLORER
1997 EXPEDITION, MOUNTAINEER
ISSUE: Available U-joints for driveshaft service are not always identifiable through model application charts. Some customers may request greaseable U-joints as a personal preference.
ACTION: Refer to the following Service Information for availability of U-joint with grease fittings.
SERVICE INFORMATION
TO IDENTIFY U-JOINT BY MEASUREMENT:
Remove the old U-joint.
Measure U-joint using the following measuring procedure.
Remove bearing cups.
Remove excess grease from bottom of bearing cups and trunnions.
Remove seals from bearing cups and trunnions.
Reinstall bearing cups on trunnions.
Measure as follows, permitting a tolerance of �0.005" at Dimension "G" with Dimension "D" and "E" at �0.003".
Outside Snap Ring Style
A) Measure "G" dimension and record.
B) Measure "D" dimension and record.
C) Measure "E" dimension and record.
Identify U-joint part number using reference dimensions in the Light Truck Cross Reference Chart found at the end of this TSB article.
TO IDENTIFY GREASEABLE U-JOINT FOR SERVICE:
For customers who demand greaseable U-joints due to their specific vehicle duty cycle, refer to Light Truck Cross Reference Chart.
Greaseable U-joints are typically recommended only for vehicles which operate 100% of the time in a high grit environment (e.g., coal mines).
NOTE: GREASEABLE U-JOINTS DO NOT CONTAIN END PLAY ****** WASHERS AND MAY CAUSE NOISE/VIBRATION/HARSHNESS (NVH) CONCERNS ON CERTAIN APPLICATIONS.
OTHER APPLICABLE ARTICLES: NONE
WARRANTY STATUS: Information Only
OASIS CODES:509000, 590000, 597997
Note that greasable u-joints are physically weaker (due to the grease journals drilled through them), and those with the grease fitting screwed in between the trunnions even moreso, due to the wedge effect of the threads. They are also less durable, due to their seals constantly being blown out by the grease being pumped through them. A sealed u-joint (which should be greased before installation, and can be re-greased by disassembly later) is stronger & lasts longer.
Depending upon if a previous owner or mechanic swapped da U Joints out, we assume you have the 1330 joints in there;
Here are comparison pics by lawdog
"Old 1330 driveshaft next to the new 1350 driveshaft."
http://i242.photobucket.com/albums/ff296/born4mud/DSC03075.jpg
http://i242.photobucket.com/albums/ff296/born4mud/DSC03074.jpg
Where is da CLUNKING?
If at slip jopint, remove boot by slicing and grease..
If @ U joint (CARDAN) replace..much cheaper than friggin w/a Jeep driveshaft in unknown condition (balance, straight & true, un-warped/stressed)
yo, some more because I had so many Error Messages for some Pic URL's due to BZ Programming
Clunk, Driveshaft "...mark it, take it out, and separate it at the slip yoke. Grease the splines heavily, and put it back together, using new clamps on the rubber boot. Be sure to mark it before taking it apart, in order to line the splines up the same way. You can also drill and tap and install a zerk fitting in the outer part of the shaft..."
Source: by spdloader
Double Cardan Driveshaft Overview, diagrams, etc. Source: by Broncobill78 (Dave) at Bronco Zone Forums
Installation, Driveshaft in an 89 Source: by publicjohncue at SuperMotors.net
Double Cardan Driveshaft Parts Break-Out Diagram
by Ford via Steve83
PTFE Lubricant; For use with: driveshaft slip yokes; especially where grunt-type noise is experienced; eliminating squeaks between plastic parts; speedometer cables; stops squeaking, sticking & binding Source: by fcsdchemicalsandlubricants.com
Troubleshooting, Driveshaft; "...chock the wheels, put it in neutral, and grab the driveshaft and twist it back and forth. examine the u-joint area for any excessive movement..." Miesk5 note; Spicer says, "...To cancel an angle vibration, the universal joint operating angles need to be EQUAL within 1 degree at each end of a driveshaft..."
Source: by memphisrain
Vibrations, General; Improperly phased or twisted propshafts; "...A twisted or improperly manufactured propshaft can have U-joints which are out of phase. This causes improper U-joint acceleration and deceleration cancellation to take place. The result is a second order propshaft speed related vibration. To check U-joint phasing, perform the following steps.." read more & scroll through the sub-topics Source: by vibratesoftware.com
Sandoval_broncosauria
