Mounting to the Fiberglass Top
Bebop Man
Rapid City, SD
I'm getting to put my roof rack on the Bronco, but before I start drilling holes, I wanted to touch base with you folks. Any thing I should be aware of before drilling through the roof? I've got 4 3x2 metal plates with 2 1/4" holes in each plate. 8 1/4" bolts total, with a matching 3x2" plate on the inside. Rubber and gasket sealer will be applied to stop water. The rack is 45" long by 40" wide. I was planning on centering it from side to side, and put the trailing edge of the rack even with the rear of the top.
bigd1948
