Manual transmission swap
fordblood
Has anyone done an automatic to manual transmission swap in their bronco? What were some of the challenges and which transmission did you choose?
Well.., it's about a 4 banana job....
These two stores have (or used to ) a list of swapout parts needed.  Auto to stick & vice-versa.
    www.tomsbroncoparts.com      www.wildhorses4x4.com
(This is for the EB but the necessary parts are the same)
Basically, you'll need;
Clutch & flywheel assy., bell housing, trannie, adaptor, output shaft, your T-case may work, dr. shaft adjustments,
maybe a new crossmember, foot-pedal assy., etc., etc. And, a lot of patience... $-)   :-"
F
fordblood
I think I'm going to find am f series and just take every thing off of it and put it in my truck. Seems like that would be the easiest way to source all that is needed.
Where's all your pics..????
Don't know if you'd like a T-18..?   Prob. better off with an OD gear.
Seems you're like me in that I like a stick-shift.  I like to "drive"  :D/   rather than "ride"  |-)  ........
F
fordblood
I've only loaded 3 pics so far. I was wanting to switch to manual transmission to have more control on the rocks and a much lower first gear. OD would be great! E9ta-ta from a 92 f series is  a 5 speed with a final drive of -0.72 and first gear is I think 5.72, which is much lower than my c6. T18 first gear is 6 something but doesn't have a helical cut firt. Lots of choices. At any rate, when I decide what I want I think finding an f series with all the parts would be ideal for sourcing.
kyleh01
