Manual Rear window
Remove the access plate and use a 12V battery to jumper the leads to the motor. Reversing the leads will change the direction so if it doesn't move swap the leads. They are the yellow and red leads along the bottom of the tail gate. If that doesn't work, then either the motor or the drive gears are bad and you will have to remove the motor, fun.
Sandoval_broncosauria
