Loud popping sound after rebuilding engine.
buildingwill
Denver
I just pulled the engine to replace the oil pan gasket, timing chain cover gasket, water pump gasket, oil pressure sensor, manifold gasket, upper manifold gasket, valve covers gaskets, etc. Basically took the whole thing apart and put back together with new gaskets. Something is misfiring though and I'm not sure what. It's my first time "rebuilding" an engine and would appreciate any help/direction of what to try.
Here's a link to the video: https://photos.app.goo.gl/XZezyVzJ4etWcmgC6
timing is wrong, could be
wrong firing order, distributor needs to be turned, or cam is out of phase from crank,
fred tyler
