Looking for body mounts
Blueveins
I am trying to find body support mounts that go on the frame in front of the front rear spring perch i've checked the graveyard lmc and autokrafters mine are all rusty and would like to replace both sides
muddrivermike
Texas Arp
I think Your talking about the steel mount thats riveted to the frame correct?There are NO replacements for them..Mine rusted out bigger than the body bushing and they started to fall through the mount...Bronco graveyard sells these oversized washers that weld into these to replace the rusted out section.I did them on mine and it worked perfectly. go here it should set you on the correct page http://broncograveyard.com/bronco/c-855 If these are what you need... :D
Wish I could get a better pic,But the washer is under the body bushing
I'll post for JSME84 since he's not here yet;
LMC Installation in an 84; the LMC core support did not fit; he modified "...by drilling a hole in the top of the frame on each side, and just running a small body mount bushing between the core support and frame..." Thanks JSM!
Source: by justshootme84 http://www.supermotors.net/clubs/superford...stry/1133/30852
