mudmonster
I was considering a suspension lift kit for my 79 Bronco. Anybody have any suggestions as to lift size, or the manufacturer? Or both?
I have 38" tires already on it. I mudbog the truck.what size tire are you planning to run. Add what type of wheeling will you be doing?27547[/snapback]
Sounds like a good buy, then. I might consider buying a Superlift lift kits. Thanks for pitching out the idea, man.I'm running a combination of superlift coils and shocks (Some dont like superlift but I'm pretty satisfied with them) with custom build everything else to get what I wanted.
27547[/snapback]
Jeff's Broncograveyard is prob the best place I've found to get the kits. They've always been good to me.Sounds like a good buy, then. I might consider buying a Superlift lift kits. Thanks for pitching out the idea, man.
28360[/snapback]
Yeah, I will have to keep that in mind.Remember to take in consideration that the higher you go on your lift, you will have to get longer drive shafts and this will add to your overall cost.
28461[/snapback]
