I've helped install 3 or 4 of the RC 4" lift kits this year. Only major problem you should have is aligning the drop bracket for the driver's side axle beam. Some of the kits had the bracket holes drilled slightly off their mark, requireing you to enlarge the holes in the bracket OR the frame crossmember. Everyone is happy with the kit as far as driving and handling. JSM84
