Left rear body sag.
BronBronBronco
Santa Clarita,CA
On my 1969 the left side of the body is 1.25" lower then the right. What would be the cause to this type of sag. Leaf springs, shocks??? :unsure:
fablife
Lacombe, Louisiana
best way is to look down the side body lines, see if they are straight.
if so check suspension by:
measurements from axle tube to frame, make sure they are the same right to left.
Tire pressure?
if not check body lift or bushings:
check measurements at the mount, if good, check the body supports for bend.
most of the time it's the front coils. hth, JD
figjeti
