Leaky oil pan
rednck7736
rednck7736
Mississippi
I have always had problems with my oil pan leaking or seeping around the gasket.I have done put a hole brand new oil pan and oil pan studs in it.Before the bolts would always come loose.They would not stay tight.So i bought studs and put them in like my 460 in my 77 F-150 has.It has been together for 7 years now and no leaks.But I can't seem to get this the 351w oil pan to stop.This has been a problem for as long as I have had the truck.I guess the only logical next step is a one piece gasket and oil pan nuts with the retainers to keep them from backing off.Anyone have any other ideas.Cause its a pain to pull the motor just for a damn oil pan gasket.I changed it once years ago with out pulling the motor.That wasnt worth it.I want do that again.
Krafty
Ontario Canada
lock tight. and make sure that the one piece gasket is what you really need, I had a one piece but it caused my 300 to leak, so a shop put in the 2 piece
