inside dash light problem
Devil Dog08
philadelphia pa
heyeveryone hope everyone is doing well. heres my problem. i have a 1995 full size 5.8 .the dash lights work only from the 4x4 button and to the right of that. temp controll panel lights work ,rear defroster light also works . all the lights in the instrument panel speedo tach headlight are not working. the problem happened right after i replaced the passenger window motor . i do not see how they can be connected but i thought i just let yuou guys know when the problem started. thanks for all your help like always.......be safe
yo DD,
Fuse Block Diagram in a 95
re your: "the lights in the instrument panel speedo tach headlight are not working"
Are headlights working?
same for tach?
and speedo working at all?
I prob will Comcast con again for a day or so;
so look @ wiring diagrams for some of those components in my site
such as;
Cluster Illumination Wiring Diagram in a 94 (99.99% = to your 95)
Source: by Mikey350 at http://www.supermotors.net/registry/media/921709
check GROUND G201 Behind bottom of LH cowl panel (driver's side kick panel)
G201 Location pic by BeastBronk http://i69.photobucket.com/albums/i42/jprix82/GEDC0025.jpg
Devil Dog08
Devil Dog08
philadelphia pa
hey miesk5 im sure glad you are still on here ..i hope everything is going well also..as for my speedo and tach they are working fine. i will look into the fuses and see whats going on . i know the fuse under the dash for the instrument lights is good . i guess the next step is to check the big fuses under the hood. its just so crazy the minute i finished putting in the new passenger door window motor the instrument lights werent working.oh yea the headlights are working fine also..thanks again for your help . i will keep you updated
ok, so it's just the instrument illumination?
if so
aside from the ground, check CKT 19 LB/R back to fuse 10 for voltage to instrument illumination
Try turning Headlight switch around to see if it is on full Dim for instrument illumination
to test Headlight switch for instrument illumination
Look in lower right panel for tests
Feel around plastic dash section around switch's shaft area for Abnormal Heat
Switch Fires, Part Number SW-2103: "...Over the past two years, this office has experienced fires caused by another potential problem in Ford vehicles. The problem exists within the dimmer portion of the headlight switch in Ford vehicles. The light switch involved is a Model SW-2103. These are the pull out type headlight switches usually located in the lower left corner of the front dash of Ford vehicles. The headlight portion of the switch has two pullout positions, the first for parking lights only, and fully out for headlights and parking lights. The shaft of this pull-out light switch can be turned clockwise and counterclockwise which activates a dimmer switch, lowering and raising the intensity of the lighting in the instrument panels respectively. Fully rotating the shaft counterclockwise past a notch activates the interior lights within the vehicles. The potential problem exists within the dimmer portion of this switch. The dimmer mechanism consists of a metallic resistive coil set inside a ceramic disc positioned over the shaft of the switch. The coil is exposed on its front side away from the passenger compartment. The front side of the coil passes across a contact permitting a current to flow through a certain portion of the coil when the switch is pulled our in its first or second positions. The greater amount of coil through which the current is permitted to pass (clockwise most position) creates the greatest resistance and therefore dims the dash lighting to its lowest intensity. The opposite position provides greatest intensity. Through our investigations, we have found that the coil can fail owing to wear and/or possible material defects or damage. A fractured coil can maneuver itself free of the ceramic disc permitting it to come in contact with the metal bracket which mounts and grounds the switch to the vehicle. When this occurs, a current can flow through a portion of the coil creating high temperatures melting the metal material of the coil and possibly igniting surrounding combustibles. This mechanism has been observed in three separate incidents by this office. Two of these resulted in a fire. The mechanism is precipitated by wear and/or defect in the coil mechanism. If the former is true, we expect there will be an increase in fires caused through this mechanism given an increase in service time. To this date the problem appears to be somewhat limited. However, this particular light switch has been utilized in numerous Ford vehicles. Therefore, a small increase in failure rate owing to age and wear could result in a significant increase in fire losses. The SW-2103 Light Switch Assembly discussed above is reportedly installed in the following Ford vehicles: 1986 -1997 F100, F150, F300; 1990-1994 Explorer; 1987-1994 Ranger; 1987-1990 Bronco II; 1992-1997 Aerostar..." Miesk5 NOTE: a shop or PO could have installed this PN in other model year Broncos, see the Ford info below in the Buyer's Guide Results by FORD: Part Number: SW2103 Description: Headlight Switch, Manufacturer: Motorcraft. Years: 1990-1994 Applications: 535: 1992-1994 Bronco; 1990 Bronco II; 1990 E-150 Econoline; 1990 E-250; 1990 E-350; 1990 ******; 1991-1994 Explorer; 1992-1994 F Super Duty; 1992-1994 F-150; 1992-1994 F-250; 1992-1994 F-350; 1990-1994 F53; 1990-1994 F59; 1990-1994 Ranger
Source: by waltersforensic.com
