Thanks "Blade" !
Okay here's another question about the MSD 6/AL . Isn't the "Spark Cycle" something like 20* of Crank Rotation ? In that case would you need to back off the initial timing to prevent detonation ? I'm running 14*-16* initial timing ( I think stock is 10* BTDC -94' 351) , so at that setting I'd theroretically be getting spark after TDC . Do these 94's with the EEC-IV have a knock sensor ?
I guess for ease of installation , MSD would be the way to go since it's a "Plug-n-Play" system . I sure like the MSD Coil, Bosch Plugs and those Taylor Wires . Made a world of difference so far . Be nice to get the MSD 6AL ,drop in distributor and Harness .
I'd also like a cam that comes in at about 1800 rpm. (Lunati has one that is real close or right in that range for $320.00) . So all in all about another $1400.00 for the Ignition and top end . Then,,,,, a T/C with about 2200 rpm stall but I see them around $1100.00 .
The truck cruises at 2,000 rpm. @ 70mph. ; but when I'm hauling a load or yanking something down in 4xLow Gear or 4xLow/Low The cam would be "right there" as the truck is usually in the 2-3k rpm band . It's a damn shame my new engine is such low compression . If I had the casg I'd build a 351W up to about 9.5:1 , I think mine may be about 8:1 if I'm lucky (Static Compression "dry" was @ 125 psi on install - I haven't done a new compression test on it yet , it's got less than 5k on a new engine) . I can't see an increase of 30-40 psi even after the rings have seated happening .
I don't want a "Racer" I actually want decent mileage and hauling ability . The days of Hot Roddin' and given way to MPG and how big a load I can move .
I love it , it's a great rig on and off road . good ride , and those adjustable shocks are great when hauling . But it does need some air bags between the frame and the rear springs . Sometimes I get the headlights "shootin'at the moon" and on our roads that's a "dog" when the front suspension gets unloaded and it starts to wander .
Steve
Matt ,
PS - Sorry to "Hijack" your thread . I just wanted to share what I'd done to my 94' and the improvements and it's kinda snowballed .
