Hidden build sheet!!
Blue beast
:ph34r: /emoticons/[email protected] 2x" width="20" height="20" /> There is hidden build sheet in broncos!! Pull out your driver seat and maybe the center console, And pull back the carpet.
It should be a piece of paper stuck to the floor under the seat. It has all kinds of codes for every option that is installed, It is basically
a big time breakdown of what parts were requested or for the area it was sent to!! IF you got the time pull it out and see what yours
has on it. I will try to scan it and post it so we can compare.
:ph34r: /emoticons/[email protected] 2x" width="20" height="20" /> There is hidden build sheet in broncos!! Pull out your driver seat and maybe the center console, And pull back the carpet.It should be a piece of paper stuck to the floor under the seat. It has all kinds of codes for every option that is installed, It is basically
Gotta give you a 10 for enthusiasm but have you read thru the archives yet ?
http://broncozone.com/forums/index.php?showtopic=5989
http://broncozone.com/forums/index.php?sho...;hl=build+sheet
Depending on where you're at and how old it is a lot of them just don't survive. Once the floorboards start to go the moisture gets at them and that's it, Last I checked the link for the buildsheet was dead so if you've got yours great but otherwise I don't know that they're available thru Ford any longer or if they are we don't have a good link for it.
yo!
the ph # Build Sheet (BS...no pun intended...!) is still good-to-go
yo!
Build Sheet Information Phone Number, Ford (1-800-392-3673) - FREE!
here is what you will receive from Ford
Build Sheet Information Form; Fords build sheet reply letter w/original build date, optional equipt., axle ratio, paint color, etc Source: by equivalent
& da old Ask Kate addy is now;
https://secure.ford.com/servlet/Satellite/f...rate-button.y=8
but, I can't do a sample from this location today w/this steenkin' laptop crap.
of couse these letter format BS's are Not as inclusive as original BS found under carpet/mat in cab or in cargo area under same.
I am still trying (a lot) to get Coding Break-out from Ford (other than commonly available VIN, diff, wt., engine, build location...., etc.)
yo!the ph # Build Sheet (BS...no pun intended...!) is still good-to-go
yo!
Ok, My bad. I've been trying the build sheet link for a couple days and kept getting a page saying it was unavailable or had been moved. I ck'd it again a few min before I posted and still couldn't connect but then again it's not like I have a high-dollar ISP either. I'm generally too lazy to pickup the phone but what the heck I'll give them a shout.
Gryph
