HELP
Anti-ricer
ok tomorrow im trading my mustang for a 95 bronco on 35s with a rough country 6in lift.it has a 351 and is a auto with a little rust on the rear wheel wells.what are some problem areas on the 95 to look for incase I change my mind on trading.it also needs to ball joins for the front
Hey Anti,
The only problem areas I found, as far as rust, are the rear wheel wells. Look up high where the rear seat belt anchors are welded to the wheel tubs.
Ball joints aren't really hard to change. Just do them all if you can, and have your Bronc aligned after.
I know of no other common chronic problems. The Beast (a 96) is still going strong with 178K miles.
Good luck
Unless you are in the desert, I have never seen a Bronco that didn't develop rust-out in the lower tail gate section where the outer skin and inner frame connect. It is preventable, but FORD never took the time to do what is necessary to prevent it.
Also, the lower B-post area tends to collect dirt and moisture which causes it to rust out.
Other favorite rust areas are the rear corner of the 1/4 panels, rear body support member, driver side floor board, front fender wells where the outer skin and inner support connect (collects dirt and moisture), rocker panels, lower door skin where the skin and inner frame connect.
If you see a blister, you are looking at the tip of the iceberg.
Check out the body work pictures on my site below if you want to see where these places are.
Good luck on your quest and don't let a little rust ***** you, it is all fixable and depending on your psychology it might even be fun :rolleyes: .
A
Anti-ricer
Thanks guys I picked it up today and couldnt be happier.I cant get over 55 tho cause I need them ball joints replaced.it pulls hard to the left if I speed up and the steering wheel is out of line.also does anyone know what size bulb a 95 bronco uses? im going to buy some hids for it (ddm) so I can see better in the woods
Coastersfwb
