Help
Tyrell_Shoaf
Albany Tx
i just got my bronco the other day and today i was in my backyard in 4x4 and all of a suden my lights and bronco turned off and wolnt start know and it wolnt jump start either and the guages dont move when i turn the key like they used to so i think it is a problem with my battery or sumthin but im not shure. it has a optuma yellow top that looks brand new but a friend came and looked at it and said it might be the silenoid not shure if that is what its called but it is what the wires off the battery connect to if anyone has any idea pleas post and help me thanks
sorry for posting this twice but i nead help fast because this is my daily driver and i have school in the morning
I'm not familiar with the electric in trucks of your vintage but it could be one or more of several possible problems:
1. The battery may be dead. Check the voltage at the terminals.
2. Remove the cables from the battery and clean them and the battery posts.
3. Could be the connection at the solinoid where the cable from the battery connects, remove nut and clean the lugs and terminal.
4. Check where the negative cable from the battery connects to the engine block, take it off and clean it.
5. One of the battery cables may be bad.
6. If your truck has fusable links you may have blown the main link. It will probably be right next to the solinoid where all the wires connect.
7. If your truck doesn't have fusable links check to see if it has a main fuse, it may be blown.
Broncoholics
Broncoholics
Washington State
Check if power is getting to the key. Might even need a new key switch.
Do the lights come on? If not sounds like a loose connection on battery or on the frame or starter. but could be the solenoid. They are cheap so after checking to make sure everything is tight, replace it. If that doesn't work it could be the voltage regulator failed and drained the battery. Try charging the battery over night. Could be the alternator not charging the battery. If it fires up after charging then its not the battery. Otherwise you have a short somewhere... :blink: Do you have lots of stuff plugged to the back of the key? might have popped that fuse.
T
Tyrell_Shoaf
Albany Tx
well i had my step dad take a look at it and he thinks it is the silinode he told me he would have it running when i got home for lunch today so maby it will be
S_bolt19
Colorado
Sounds like the starter selinoid. I usually carry an extra one around for that particular reason. They can go out at any time. Question though? when you turn the key on does it just sit there and "click, click, click"? if it does then go down and buy a selinoid and replace it. No big deal. You also might want to check what side your negative on the battery is. If it is on the side closest to the fender, it could have come loose and slid over and grounded out. Then you just need to find the right fuse and replace it and tie that battery down a little better. But it sounds like the selinoid went belly up on you....if thats the case, carry an extra one around with you.
Glad you got it fixxed. I go thru 2-3 of those a year, so always carry a spare!!!
fred tyler
